Looking to spend 100-170 on a new monitor hoping that they will go on sale this week!! if anyone sees something that i should be looking at please post! it would be greatly appreciated seeing as so many websites are offering deals like this!
$199.99 -- $20 out of your range, but worth looking. http://www.newegg.com/Product/Product.aspx?Item=N82E16824176194
$159.99 -- within budget, but 5ms response time vs the 2ms of the above HP. http://www.newegg.com/Product/Product.aspx?Item=N82E16824260050
$159.99 -- 2ms response, within budget, but not a well-known brand (to me, at least.) http://www.newegg.com/Product/Product.aspx?Item=N82E16824262025
If you browse newegg, I'm sure you could find something you'll fall in love with.
ah appreciate it man. will see if any of those continue to go lower in price ^_^
If you can, keep an eye on this and pick it up if it drops in price! I'm not sure if it'll drop below its current price, mainly because it's $25 off ends today. Either way, add it to your list :)
I love ASUS monitors, and imo this is the best one you can get for under $200 at the moment.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
had my eye on that one for a while ^^^ definitely would pick it up if it continues to go down (likely will)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009421&cm_mmc=BlkFri2012-_-20-_-N82E16824009421-_-na&nm_mc=BlkFri2012
whats everybodys take on that? $110
