B-day present for son. 1st pc build need experienced builders critique!
My first pc build…specs below.
Hoping to get responses quickly because this is for an upcoming birthday present and I need to order components asap.  Open to suggestions and tech savvy opinions on my specs and any insight of possible issues of components bottlenecking or useless upgrades.  My son has wanted an Alienware gaming desktop and I just can’t see spending that kind of money on an OEM hyped up pc.  It took a bit to convince him that I could build one just as good and he still is somewhat skeptical but I am giving it my best shot and hope to WOW him.  He is a heavy Xbox gamer currently with favs being Skyrim, BF4 and really wants to do pc gaming of Skyrim and Rust and some video creating/editing. Any heads-up advice for first time builds would be appreciated as well.
CPU.Intel Core i7-4770K
GPU.Gigabyte GeForce GTX 770
Mobo.Gigabyte GA-Z87X-UD3H
PSU.SeaSonic 620W
Heatsink.Cooler Master Hyper 212 EVO
Case. Cooler Master HAF 932 Blue
G.Skill 8GB
Storage.Samsung 128GB SSD
              Seagate 2TB 7200RPM
OD.Lite-On IHAS324-07
Wifi Adapter.Asus PCE-AC68
Looks great to me!  I hope he enjoys it.
Looks great! This is way better than Alienware.  Maybe he would be interested in learning how to build a pc? Maybe you can go through it with him and he would enjoy it.
Budget? Resolution of monitor? It's probably best to back down a little on the CPU and get a 290X or 780
Looks very nice - you may get better feedback if you suggested budget etc.
Only thing I would consider changing at the moment is that air cooler. It will do the job, but the 4770K gets quite hot. I personally am a fan of Noctua (pun intended). This is a good one, pricier, but very good (lower noise and temperatures):
http://www.noctua.at/main.php?show=productview&products_id=34&lng=en
It should fit in that case with ease. Noctua coolers tend to be more compatible as well with their asymmetrical design.
Other people may have other suggestions.
 Yah I hope it blows Alienware owning friends out of the water.  lol  And I am hoping he will join in on the build, it would be a great learning experience for us both!!
Oh great I am up for any suggestions. I am pretty much on budget but willing to go up a bit for performance.  I almost went with a water cooler but thought I would start without one and see how that goes.  I will definitely check the Noctua out. Thanks!
YOU WIN DAD OF THE YEAR!!!! Yea looks fantastic! However i do agree with William on this one. going a little cheaper on the CPU and putting that money into getting a GTX 780 Is totally worth it. But either way its a killer build and would blow mine out of the water.
I would recommend getting a modular version of the Seasonic power supply to make your life easier.
For the case I recommend an NZXT Phantom 530 or a Corsair Carbide Air 540.
Other than that everything looks good
the NZXT 530 is a good thought. It has that alien ware look to it if he really wants it.
Wait... my bad just saw your name... YOU WIN MOM OF THE YEAR!!!!!!!
Okay maybe go to an i5-4670 and up the GPU to a 780?  Probably just going with a 1920 x 1080 res monitor for now, haven't gotten that far yet.    Budget is somewhat flexible.
No prob,  lucky kid has a geeky mom!  lol!
I also like it for water cooling support, so if he wanted to try make a custom loop later on the support for it would be there and it has fantastic features at its price
Just looked at the NZXT 530 case that does look pretty cool.  As for case recommendations are they based off of looks or ease of building, room, quality?
Phantoms are good cases to build in, they are usually roomy, have lots of room for cables, a fan hub in the back, a fan controller built in (I think), and they look good.
Yes, sounds good. You could also consider an FX 8320 or 8350 for the CPU, they'll perform similarly in gaming to the i5 and probably cost a little less.
Wish my mom was that cool. :)~
Alright changing specs to the Phantom case and a modular psu, going down on the cpu but stepping up on the gpu!!!  This is a very helpful forum!!!  Thanks!!!
Okay thanks the prices are lower!!!  I am gonna check some benchmark comparison sites and make a decision but you think putting more money into the graphics even without a high res monitor would be best?
