So this is here partially for y’all @SgtAwesomesauce @kreestuh @wendell for this years devember and mostly here for peoples reference. A constant struggle was restart resilience of a server crash. Originally we couldnt test this process in prod so we just let it slide. But I want you to have it for future reference. Considering you might go creative this year. You probably want it to restart after a crash right?
Wendell could you potentially tarball up and send to me the worlds? Or at the very least the spawn world that I created for you all? Id like to have it. I created it as a one off with inspiration from various builds. Turns out its damn nice and id like it for my own server/archive purposes.
Lets begin
Im running Fedora in this setup so the directions will be tailored for Fedora. Lets install some prerequisites before we run paperMC
sudo dnf groupinstall -y "development tools"
sudo dnf install -y java-latest-openjdk.x86_64
sudo dnf -y install setroubleshoot
Now we can build MCRCON which is what we will need to access the remote console. However before we do so its up to the server owner whether or not he wants to create a minecraft user. I recommend this step and its pretty easy to do.
sudo useradd -r -m -U -d (path to MC install directory in my case ZFS vols) -s /bin/bash minecraft
My actual command looks like this
sudo useradd -r -m -U -d /mnt/OnePoint21GigaWatts/games/PaperMC -s /bin/bash minecraft
What this is going to do is install the home directory of this user we create on our ZFS pool. I prefer it this way and honestly the load times are just as sweet as my SSD so it has little effect.
Now, switch to Minecraft user by executing the following command:
sudo su - minecraft
Now we are going to make a few directories.
mkdir -p ~/{images,mcrcon,server}
The directories are simple. The images directory is for storing a regular backup image of the server. The mcrcon directory is for our remote console we will build from sauce. The server directory will store the Minecraft server and the related items.
Now we can build MC-RCON. Theres a git for it. Its ultra simple.
cd ~/mcrcon && git clone https://github.com/Tiiffi/mcrcon.git
cd ~/mcrcon/mcrcon
(this is dirty it could be neater)
Run it through GCC. (One does not need all these flags I just like using the flags for my arch)
gcc -std=gnu12 -pedantic -Wall -Wextra -znver3 -O3 -s -o mcrcon mcrcon.c
You can just as easily use a generic GCC11
gcc -std=gnu11 -pedantic -Wall -Wextra -O2 -s -o mcrcon mcrcon.c
Now make it executable and run it to test
chmod +x mcrcon && ./mcrcon ?
Snag the MC jar file. Grab it from here for paperMC Downloads – PaperMC
wget <URL> -P ~/server
Lets move to the directory and execute the server first to handle some of the operations that will create server.properties and the acceptance of the EULA before we write the systemD service.
cd ~/server
java -Xms10G -Xmx10G -XX:+UseG1GC -XX:+ParallelRefProcEnabled -XX:MaxGCPauseMillis=200 -XX:+UnlockExperimentalVMOptions -XX:+DisableExplicitGC -XX:+AlwaysPreTouch -XX:G1NewSizePercent=30 -XX:G1MaxNewSizePercent=40 -XX:G1HeapRegionSize=8M -XX:G1ReservePercent=20 -XX:G1HeapWastePercent=5 -XX:G1MixedGCCountTarget=4 -XX:InitiatingHeapOccupancyPercent=15 -XX:G1MixedGCLiveThresholdPercent=90 -XX:G1RSetUpdatingPauseTimePercent=5 -XX:SurvivorRatio=32 -XX:+PerfDisableSharedMem -XX:MaxTenuringThreshold=1 -Xlog:gc*:logs/gc.log:time,uptime:filecount=5,filesize=10M -Dusing.aikars.flags=https://mcflags.emc.gs -Daikars.new.flags=true -jar paper-1.19-34.jar --nogui
This will fail for needing the sign the EULA and you can do that via
nvim ~/server/eula.txt
and setting eula=true. Now before running again lets setup the RCON in the server.properties file. Find the following and set/edit as follows
nvim ~/server/server.properties
Values to change:
- rcon.port=25575 (or change it if you like)
- rcon.password=(I set this to a random long string of alphanumerics+special characters)
- enable-rcon=true
We need to create a systemD file that integrates nicely, drops privileges and does not make SELinux freak out if enabled.
[Unit]
Description=L1 Minecraft Server Service File
After=network.target # We want it up after network has been handled
[Service]
User=minecraft
Nice=-20 # Set niceness level. For me I like it to be the priority
SuccessExitStatus=0 1 # Define exit statuses
# System Protection Flags and Privilege Dropping
ProtectSystem=full
PrivateDevices=true
ProtectHome=true
NoNewPrivileges=true
WorkingDirectory=<path to SERVER directory>
# Tweak these flags as you see fit
ExecStart=bash -c 'java -Xms10G -Xmx10G -XX:+UseG1GC -XX:+ParallelRefProcEnabled -XX:MaxGCPauseMillis=200 -XX:+UnlockExperimentalVMOptions -XX:+DisableExplicitGC -XX:+AlwaysPreTouch -XX:G1NewSizePercent=30 -XX:G1MaxNewSizePercent=40 -XX:G1HeapRegionSize=8M -XX:G1ReservePercent=20 -XX:G1HeapWastePercent=5 -XX:G1MixedGCCountTarget=4 -XX:InitiatingHeapOccupancyPercent=15 -XX:G1MixedGCLiveThresholdPercent=90 -XX:G1RSetUpdatingPauseTimePercent=5 -XX:SurvivorRatio=32 -XX:+PerfDisableSharedMem -XX:MaxTenuringThreshold=1 -Xlog:gc*:logs/gc.log:time,uptime:filecount=5,filesize=10M -Dusing.aikars.flags=https://mcflags.emc.gs -Daikars.new.flags=true -jar paper-1.19-34.jar --nogui'
ExecStop=bash -c '<path-to-mcrcon-executable> stop'
Restart=always # Restart if it fails
RestartSec=3 # How long to wait between failures
[Install]
WantedBy=multi-user.target
Enable but do NOT start the service yet.
sudo systemctl enable minecraft.service
We need a few bash aliases to make our life a bit easier when we shell in to access our RCON. Now I have defined them but I leave their declation UP to you. You can either set them globally in /etc/environment
or in the .bashrc
of the minecraft user (Dont forget to source it)
# MC RCON Variables
export MCRCON_PASS="<password>"
export MCRCON_HOST="127.0.0.1"
export MCRCON_PORT="<port>"
# MC RCON Terminal Access
alias mct='<path to mcrcon executable> -t'
# MC RCON Stop Server
alias mcs= '<path to mcrcon executable> stop'
Pretty simple right? and once you source this its easy to RCON in
Now I am going to leave the firewall configuration, tunnel configuration and backup configuration up to you. Everyone has their own style and it seems futile to recommend a specific way. If you are using systemD then systemD should handle the scheduling of your backups.
Start the minecraft server
sudo systemctl start minecraft
In a TMUX window you can monitor in a divided window the logs of the server by using the journal.
sudo journalctl -feu minecraft
You can access RCON via the alias I set above for terminal model in the other side of the divided window via
mct
IF you have SELinux issues like I did because you dont run permissive mode… Make sure systemd-minecraft has a local policy
ausearch -ts <BEFORE SERVICE RESTART> -te now --raw | audit2allow -M allow-systemd-minecraft; semodule -X 300 -i allow-systemd-minecraft.pp
That is really all there is to it. Good Luck, Have Fun, Configure your stuff and Profit
P.S This works flawlessly for my own server. Its really nice to just pull the logs from systemD. Now this could be customized so much more but I kept it simple as a starter place for everyone.
You can extend this concept for:
- The modern, next-generation Minecraft server proxy forked by PaperMC
- PaperMCs fork of the BungeeCord software, with improved Forge support and more features.
- Any additional servers you need to run just tweak the configs and make the new ones for each
