Hello!
In my homelab I have a VMware ESXi 6.5 Server.
One of the VM’s is a WDS server with MDT.
I have separate VM’s for each Windows version. The VM’s are also setup with non persistent disks.
Due to resource limitations, I can’t efficiently run more then one at a time (limitations when the homelab consists of OLD computers…).
And it gets quite tedious to start them manually one by one (can take 2-3 hours per image…). Or shut them down if one hangs…
My current need is to find a way to start one VM after the previous one has powered off.
Second it should force shutdown the VM if power on time equals X amount of hours.
I was reccomended to make a PowerShell script with PowerCLI commands.
But I have no experience with PowerShell or PowerCLI (or any other coding).
Could not find any guides online that fits my need.
So I was wondering if someone could point me in the right direction?
Thanks
-Yngve
