Hi Guys,
I'm looking to build a pc for the first time. I am currently at university and looking to build a pc for mainly 2d Autocad use and Google Sketchup (3D) with enough scope to use Revit in the future.
I'm getting a bit confused as to what to go for to be honest. Ideally I'd like the following specs;
- 8+GB RAM (with capacity to add more)
- 240Gb SSD
- 1TB HD
- Possibly a graphics card (However, this isn't a top priority but ideally could be added in the future)
So what I'm after really is suggestions on the parts to use i.e motherboards etc.
I know this is fairly brief but I'll try and answer any questions you guys have.
Budget wise I'd like to keep it under £600 if possible (920 usd).
Cheers guys hope you can help.
J
