Australian $800 Build
So i'm thinking of selling my current build off on eBay and upgrading to a more future proof and up-gradable PC. So basically I should have around $800 give or take that i'm willing to spend on this but with the new intel socket ive kinda fallen behind on whats the best performance I can get, with the option for FUTURE UPGRADES. So while I love a good old budget amd which will of course give me better performance for money I am looking for an intel build on haswell hopefully.
If you guys could help me out with an appropriate build I would really appreciate any help! Also I am feeling a fractal arc midi r2 as my case but im open to any suggestions if you guys think there's any better. (keep in mind Australian prices are a bitch)
Thanks guys
What's your build already? So i know if there are any salvageable parts in there that could cut costs.
And with a Haswell build it would take half you budget just for the motherboard and cpu.
Right didnt realise there price, as I said bit behind on current things. I'll have to go with an 1155.
Currently have
cpu: amd a10 5800k
Mobo: asrock fm2a85x extreme 6
Hardrive: western digital 1tb (black I think)
Ram: 2133 mhz g.skil ripjaws
Cooler: coolermaster 412 slim
case: nzxt phantom 410
Power: corsair gs600watt 80+
Not to sure about taking anything out of that as like I said Im selling on ebay but I will flog a couple of fans. Im not expecting much of a performance boost but I just want the option to upgrade cpu of gpu later.
Well there is alot of things you could salvage but due to you selling you wont be able to salvage anything.
Here's a build I've done.
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=180767&action=wish_lists
It's over $800 obviously. But this is the least i would do. You could make it even cheaper if you didn't want a arc midi r2.
With an Intel equivalent of this build you will probably have a 7770ghz and a much cheaper case. Because a 3570k or non k is around $240-270. So nearly all of your budget is still blown out of the water just with the motherboard and cpu.
yeh I knew I would have to end up with a 6300, thanks for your help ill do some research on the parts.
Cheers
No problem.
