So i'm just stopping by to ask this, does the Audio-Technica AT2020 USB pick ambient noise badly? My keyboard has Cherry MX Brown switches, would it be a bad idea to get this mic for gaming etc? I'm just worried 'bout the ambient noise of this mic, didn't really find any material on that. And of course, anwser preferably from someone who has it or have used it.
It should be fine just lower the gain some. I use mine for the same purposes and it works fine. I also have a corsair k70 rgb in brown switches.
Your answer is greatly appreciated, thank you.
Nomen est omen lolz...
