I have been asked by a friend to build them a computer to go in a sound studio for the band the computer it self is not a issue for me my problem is what sound interface would you recommend
will need XLR and 1/4" inputs and a few outputs for headphones
Well if they have a sound studio already they should have a mixer. The mixer should be able to interface with the computer somehow. Either via usb or line in with an 1/8" cable.
I don't know about exactly 20 but there are ones with 28, 36, 56, 64, etc. Be prepared to spend a lot of money though. Which reminds me I don't even know what kind of budget you have bulldog.
Probably not in one unit but that doesn't really matter. My Profire 26/26 only has the full 26 in 26 out when using more than one unit together. I'm not sure how many interfaces are capable of being chained with a master and slave setup though.
Drums and live music are the only things you need to use lots of inputs at once for. Everything else can be done individually. Better takes and less money spent.
If you want higher end and budget is just a matter of how many zeros you can fit on the check, then things get real interesting :)
If your budget is lower... well I'm sure someone else will be able to recommend something. And there's always eBay! No reason you can't hodgepodge together a few smaller, secondhand interfaces, or get a firewire card and a used MOTU and some preamps.
If you could give specifics on budget and DAW selection, I bet people might have more to say. It's also kinda hard to make recommendations without knowing things like what level of quality you would consider acceptable versus your need to expand. Of course budget often ends up being the deciding factor, but still there are quite a few options out there.
Also keep in mind that you will most likely have to get a separate headphone amplifier unit. Most interfaces will maybe give you one or two headphone outputs, and the rest of the outs will be line level and require amplification to drive headphones. This might be another advantage of using multiple smaller interfaces. You could have one by each band member, and just run long USB cables back to the recording workstation. That way there is a headphone output and volume control right by each artist. Kinda a sloppy solution, but it might work.
