Hey everybody,
I had a VFIO/KVM with W11 just for gaming. Everything was grand, except W11 itself. I was fed up, so I decided to go back to W10. Without changing anything in the KVM XML, I booted up with W10 ISO and did a clean install of Windows.
All looked good, until I noticed there is an audio lag of about 1-3 seconds all the time, resulting in some intense games to be unplayable.
I had this issue long ago, but then I was using pulse audio, and the solution I applied and worked, was this one (from my notes):
<qemu:commandline>
<qemu:arg value='-device'/>
<qemu:arg value='ich9-intel-hda,bus=pcie.0,addr=0x1b'/>
<qemu:arg value='hda-micro,audiodev=hda'/>
<qemu:arg value='-audiodev'/>
<qemu:arg value='pa,id=hda,server=unix:/run/user/1000/pulse/native'/>
</qemu:commandline>
Append the following lines to /etc/apparmor.d/abstractions/libvirt-qemu
/etc/pulse/client.conf.d/ r,
/etc/pulse/client.conf.d/* r,
/run/user/1000/pulse/native rw,
/home/wizard/.config/pulse/* r,
/home/wizard/.config/pulse/cookie k,
However, I am running pipewire now, so I assume this won’t work.
Any ideas how to make it work, or if there is another solution for pipewire?
inxi -F
System:
Host: manjaro-pc Kernel: 5.10.131-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.6 Distro: Manjaro Linux
Machine:
Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS MASTER serial: <superuser required>
UEFI: American Megatrends LLC. v: F36b date: 02/16/2022
CPU:
Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP cache:
L2: 6 MiB
Speed (MHz): avg: 3101
min/max: 2200/5994:6294:6442:6146:5846:5102:4950:5698:5550:5398:5250 cores:
1: 3938 2: 3799 3: 2880 4: 2879 5: 2879 6: 2879 7: 3599 8: 2877 9: 2878
10: 2876 11: 2871 12: 3599 13: 3374 14: 3598 15: 2878 16: 2879 17: 2879
18: 2874 19: 2879 20: 2897 21: 2878 22: 2875 23: 2875 24: 3598
Graphics:
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: vfio-pci
v: 0.2
Device-2: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] driver: amdgpu
v: kernel
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: amdgpu unloaded: modesetting,radeon gpu: amdgpu resolution:
1: 1200x1920~60Hz 2: 2560x1440~60Hz
OpenGL: renderer: AMD Radeon RX 5500 XT (navi14 LLVM 14.0.6 DRM 3.40
5.10.131-1-MANJARO)
v: 4.6 Mesa 22.1.3
Audio:
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: vfio-pci
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel
Device-3: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-4: Creative Sound Blaster GC7 type: USB
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid
Device-5: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.10.131-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.56 running: yes
Network:
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlp6s0 state: down mac: 6e:bf:5c:cb:9e:fe
Device-2: Intel I211 Gigabit Network driver: igb
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e
Device-3: Realtek RTL8125 2.5GbE driver: vfio-pci
IF-ID-1: virbr0 state: down mac: 52:54
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Report: rfkill ID: hci0 state: up address: see --recommends
Drives:
Local Storage: total: 5.93 TiB used: 1.13 TiB (19.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB
ID-2: /dev/nvme1n1 vendor: Seagate model: XPG GAMMIX S50 Lite
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO 250GB
ID-4: /dev/sda vendor: Toshiba model: HDWE140 size: 3.64 TiB
ID-5: /dev/sdb vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
ID-6: /dev/sdc vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
Partition:
ID-1: / size: 448.43 GiB used: 204.72 GiB (45.7%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
Sensors:
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1316
Info:
Processes: 530 Uptime: 49m Memory: 62.73 GiB used: 23.44 GiB (37.4%)
Shell: Zsh inxi: 3.3.19
ps. I posted this yesterday, but I deleted it as I thought I fixed… well…no…
