I’ve been having this problem for quite a long time on my Hyperbook NH7 (Intel 10870H and RTX3060, Polish rebrand of Clevo, msinfo32 shows the model as NH5x_7xDPx), as in title, most of the time everything is working fine, but once I start a heavy load (I’ve seen it happen the most when compressing with 7zip, which includes high cpu and drive usage), after some time audio starts crackling a lot, all USB devices start to freeze (they don’t disconnect in device manager though, just freeze in random intervals). Aside of freezing, the cursor can jump around on the screen, click some things, and system can behave like some of the modifier keys are being held, like ctrl, alt, etc. Bluetooth mice, touchpad and built-in keyboard are not freezing though.
It happens on both Windows 10 and 11. I’ve seen it happen less when I set “PCI Express>Link State Power Management” to “Maximum power savings”, laptop software keeps setting this to “off” in performance modes. It doesn’t remove the issue entirely though.
Aside of GPU driver updates I don’t use any other drivers than those provided by Windows Update (also tested with optional updates). BIOS is the newest I’ve seen for the laptop (v1.07.06 for model NH5x_7xDPx). I also don’t use any overclocking software.
I thought it’s caused by BIOS power management settings, but only thing I see there is FlexiCharge and GPU performance scaling, which didn’t fix anything. I’m not sure where to go with this, could it be caused by a faulty USBC connector? I’ve been connecting a Baseus CAHUB-C0G to it since I got the laptop, so it could damage it over time I guess? When I wiggle the connector side it can very rarely disconnect and reconnect the hub. Now I use a Unitek Y-3197 hub which is USB-A, it does not disconnect when wiggling, but all previous issues still happen.
What I have connected over USB is mouse, keyboard, audio interface and gamepad. Also when I connect an SSD to the USBC port it sometimes gets really hot without doing anything for a long time (doesn’t happen when I connect it to other PCs)
Do you know any ways of properly separating this issue? I can’t really find a consistent pattern of it failing.
