I need your stock air coolers
Frontier and wx9100 coolers would work too
Just air coolers, not interested in water cooling
I am based in Kentucky
lol you want to try the same?
are you going to try to fit it to a MI25?
Yes
Guess I will have to stay up to date on the result, would be awesome if they are a perfect fit, though would mean I would need to find a cooler myself
Oh, you want the entire cooler? Could probably buy just the fan and take a hole saw to the base plate. Well, you’d definitely cut through that heat pipe doing that.
