My aunt just gave me a WD Passport 1TB drive - I removed it from the enclosure and plugged it via the USB3 cable into my Threadripper box to watch the logs in Fedora 26. Looks like this is pretty hosed, any ideas on things I could try?
It just keeps giving a clicking sound…
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Read Capacity(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Sense not available.
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] 0 512-byte logical blocks: (0 B/0 B)
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] 0-byte physical blocks
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Write Protect is off
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Mode Sense: 00 00 00 00
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Asking for cache data failed
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Assuming drive cache: write through
Oct 28 14:08:25 threadripper kernel: sd 10:0:0:0: [sdc] Attached SCSI disk
Oct 28 14:08:25 threadripper systemd-udevd[59485]: inotify_add_watch(11, /dev/sdc, 10) failed: No such file or directory
Oct 28 14:08:36 threadripper kernel: usb 8-3.1.3: new SuperSpeed USB device number 5 using xhci_hcd
Oct 28 14:08:36 threadripper kernel: usb 8-3.1.3: New USB device found, idVendor=1058, idProduct=0810
Oct 28 14:08:36 threadripper kernel: usb 8-3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 28 14:08:36 threadripper kernel: usb 8-3.1.3: Product: My Passport 0810
Oct 28 14:08:36 threadripper kernel: usb 8-3.1.3: Manufacturer: Western Digital
Oct 28 14:08:36 threadripper kernel: usb 8-3.1.3: SerialNumber: 575838314138335533353439
Oct 28 14:08:36 threadripper kernel: usb-storage 8-3.1.3:1.0: USB Mass Storage device detected
Oct 28 14:08:36 threadripper kernel: scsi host10: usb-storage 8-3.1.3:1.0
Oct 28 14:08:36 threadripper mtp-probe[59515]: checking bus 8, device 5: "/sys/devices/pci0000:40/0000:40:07.1/0000:42:00.3/usb8/8-3/8-3.1/8-3.
1.3"
Oct 28 14:08:36 threadripper mtp-probe[59515]: bus: 8, device: 5 was not an MTP device
Oct 28 14:08:37 threadripper kernel: scsi 10:0:0:0: Direct-Access WD My Passport 0810 1042 PQ: 0 ANSI: 6
Oct 28 14:08:37 threadripper kernel: scsi 10:0:0:1: Enclosure WD SES Device 1042 PQ: 0 ANSI: 6
Oct 28 14:08:37 threadripper kernel: sd 10:0:0:0: Attached scsi generic sg2 type 0
Oct 28 14:08:37 threadripper kernel: ses 10:0:0:1: Attached Enclosure device
Oct 28 14:08:37 threadripper kernel: ses 10:0:0:1: Attached scsi generic sg3 type 13
Oct 28 14:08:43 threadripper kernel: ses 10:0:0:1: Wrong diagnostic page; asked for 1 got 0
Oct 28 14:08:43 threadripper kernel: ses 10:0:0:1: Failed to get diagnostic page 0xffffffea
Oct 28 14:08:43 threadripper kernel: ses 10:0:0:1: Failed to bind enclosure -19
Oct 28 14:08:43 threadripper kernel: sd 10:0:0:0: [sdc] Spinning up disk...
This looks like the most important bit -
