I bought a MSI R7970 and I know this card destroys games.. I'm having a very weird issue that I cant pin point the cause of... Some games I can play butter smooth and other games have shakey frames.. It's not the low fps kind of frame rate issue because i'm getting 200+ frames.. It's the in between shakiness / frame snapping / objects shaking.. It's driving me beserk.. I cant tell if this is a common ati issue which i doubt, a driver issue or possibly a bios option.. i've tried 13.1, 13.2 and 13.3 catalyst drivers. I can play games like guild wars 2, dead space 3 and torchlight 2 perfect.. games like battlefield 3, crysis 3 and skyrim are some i'm gonna mention.. it doesn't matter if i have the graphics at the lowest possible graphic setting with all the effects(aa,af) etc.. turned off or everything cranked to the max.. the same issue persists... i've tried stuff like limitting fps with msi afterburner to 60,59,58 30 etc.. i've tried window mode and full screen and i've also tried stock bios settings, stock clock and 4.7 overclock as well as stock video clock and overclock..
i'm running a intel 3770k, sabertooth z77, msi r7970 lightning overclock edition, corsair vengeance 1600mhz, kingston hyperx 3k and nzxt hale82n 750watt power supply.. i feel this setup should be destroying video games.
i'm half tempted to buy a nvidia 670 next week just to see if i get the same issues..
i'm gonna record some videos and upload them on youtube in a bit.
the issue only exists when panning with a mouse.. i've tried other mouse and other monitors of diferent hz and cables of different types.
