When booting it up I am getting a A2 on the Led on the card i dont know whats wrong i've tried everything and it just keeps giving me it my specs are http://pcpartpicker.com/user/Cosmics/saved/2E7J
Btw I dont even get a screen on my monitor someone please help I am really stressed out
If you can then get it to boot to bios set all the sata devices to AHCI in the bios and reboot with the hdd reatached.
If that dosent work reset the bios by removeing the bios battery for 1-2mins (asus often test mobos before thay go out and may not have the bios set to its defults)
okay let your monitor connected to the onboard video port. try with only one ram stick, try every ram slot. piece for piece with both ram sticks sepparate.
I tried it :( and same code everything is running and fine im just not getting anything on my monitor no bios or anything & Still getting that A2 on my mobo
