Sometimes my computer will boot and there's no problem, however other times my computer will have a problem turning on, it will do a cold boot and the red CPU LED will remain on. However I have a feeling there is no problem with the CPU because when the PC is up and running there is no problem at all, it's amazing.
Specs:
i5 4570 (3.2GHz)
Kingston Hyper X 16GB@1333MHz
Nvidia GTX780 Super Jetstream 3072MB
Kingston SV300S37A120G (120GB SSD)
1TB WD Green HDD
Asus Z87-A Motherboard
Corsair TX750M PSU
Corsair 200R case
Cooler Master Seidon 120m (Not needed I know a fan cooler would have been fine, I just worry about the heat)
1 - Standard Corsair Case Fan (Intake)
2 - Bitfenix BitFenix Spectre PWM 120 (Exhaust)
- I would have more case fans but considering there's an issue when it comes to turning on, I feel like it's best I don't add more fans, I would try to include positive airflow, so that the dust inside gets blown out. However the temps are very good, idle is around 30'C and it maxes out in temps of temps at 60'C.
- I should also mention that I have tried simple fixes such as making sure that the CPU cooler isn't too tight, the thermal paste is fine, the PSU cables are nice and snug.
Can anyone help?
