Hey Guys,
so I am trying to troubleshoot issues with two Asus XG-C100C cards that simply will not behave like they should.
I’ve optimized settings for max throughput but the bw does not stay. After a few hours network speed degrades down from ~7Gbps to about 150-250 Mbps.
- Unplugging and replugging the cable does not help
- Restarting the switch does not help
- Disabling/Enabeling the card in Windows Device Manager restores speed for a few hours
Only one of the systems seems to be affected since restarting the device on the other PC does not change anything.
I’ve
- Updated drivers
- placed a dedicated cooling fan at the heatsink
- replaced all cables
- tried direct connection as well
- swapped the card to a different PCIe X16 (electronical) slot
I am out of options by now…
Have you guys any idea what could be happening here?
Thanks!
