Hi, i just registered here, so please redirect me if this is not the correct category to post on. Some months ago i was able to obtain for almost free an asus WS C621E sage. I wanted to build a maya render rig/homeserver with it. I bought 2 xeon platinum 8160 QL1K ES cpus and 96GB of samsung M393A1G43EB1-CRC to go with it. I just recieved the CPUS, and so far i’ve gotten no luck getting past code 00 on the motherboard. I know this board doesnt support ES CPUs, but the seller sent me a modified bios that is supposed to enable them. I also found this thread a thread in the win-raid forums where they have modded the bios and supposedly got it working. Even without the modded bios however, i have looked it up and supposedly it should partially post until it gets stuck in code 66. The problem is that i dont recieve the waterblocks until next week and need to test if all the components work as soon as possible to return all of it if something is broken. And because this socket doesnt have a retention lever i have to manually press down on the cpu. Also it doesnt turn on with the power or reset buttons, but if i press down on the cpu everything turns on and i get code 00. What can i do?
Hi i had that Board and a few ES xeons on that.
You need a modded BIOS for those Xeons.
When iam at home i will look If i still have it.
You need enough pressure to get any Post Codes.
I dont think you can put enough even pressure on Them.
Thats awesome to hear! i have a few modded bios from the win-raid forums and from the xeon sellers, but if you still have it it would be awesome to have more options to test. If you are right on the pressure thing its a huge relief, i’ll have to wait to test it with the waterblocks. Thank you!
