Asus WRX80E-Sage wireless module - how to disable it?
My group got two of them fully assembled from a system integrator but somehow didn’t get the wireless disabled. We cannot have wireless. It is forbidden. Period. No exceptions.
I need to turn that hardware into gone-ware, was-ware, kicked-the-bucket-ware, shuffled-off-this-mortal-coil-ware, THIS-IS-AN-EX-PARROT-ware.
Have any of you gotten the I/O cover off? How? I suspect it is via screws on the back of the motherboard but I don’t want to do that until I know it’s the right way to go about our goal. Is the module itself even under there and able to be removed without voiding the warranty, i.e., without de-soldering?
I’ll take any ideas about how to make the wireless join the choir invisible.
Thanks in advance.
