Asus Tuf B450M Bios White Light, since setting up KVM
Hello! Wanted to say I love the KVM so far (its been 3 days) but its a game changer for my new sit/stand desk at home. Really loving having this flexibility to use my gaming rig and work macbook.
I have had a weird thing occur since getting all the cables re-run. The Bios white light on the motherboard will be on when PC is running (which usually indicates a bad GPU connection or cable connection) even though the machine is running fine. Switching between PC1 or PC2 does not seem to cause it or fix, only a complete Restart will get rid of it.
I havent had any indication of issues yet - but just wanted to see if you guys had experienced this, or anyone else had? Any ideas why it may be getting itself in a snit? I assume its something to do with the DP cables going to the KVM itself rather than going to a monitor - but i am not sure.
