At the time of purchase, any model with both the 2060 and the 144hz display were sold out, so I settled for the 60hz display.
At this point, because I am already actively using the device, I figure it would be easier to simply swap the display out if I were to upgrade rather than swapping the entire device.
Are there any good website or resources for comparing mobile panels and finding one that would be compatible?
minimally I would like to find the panel used in the 144hz version of this laptop, but I have not been able to find any specific part number for it.
You can likely find specs on any panel on those 2 sites. Whether or nor you can use them as comparative cross model checking is going to be debatable. From my use of them you really need to know what you’re looking for first
