Do we know if this can be used for a wifi adapter? I know its labeled and says it can so it should be self explanatory… but were is the antenea ? is it soldered to the motherboard ?
How is this thing going to get reception ?
You will need a few U.FL/IPX to SMA Adapters, a few SMA antennas tuned for the appropriate frequencies and a PCI cover with holes for the SMA plugs to mount in.
That makes sense. Thanks for the info…sounds like a job for later.
there exist ready to use kits like this one:
https://www.newegg.com/fenvi-wi-fi-6e-fv-axe210ng-ngff-m-2-2230-interface/p/0XM-00JK-00099
I think i wanna try and get an intel wifi card for it.
Thanks for the info. I have a kit inbound now ^^ .
https://a.co/d/57s3PCh
Can this card work while PC is in S3 state?
That is a good question i am not sure. I should be getting it tomorrow though i dont really sleep my computer ever.
Can i ask if the ax211 worked?
I want Bluetooth for peripherals like mice and the resolve speed editor but figured may as well get the best the board can use.
Block diagram says wifi6,bt5.2 but I on a 1xpcie3 lane so hoping drivers exist for the ax211.
