As the above topic states im really struggling on getting a new motherboard for an fx 8350 im debating between
ASUS sabertooth 990fx r2.0
or
ASUS m5a99fx Pro 2.0
The m5a99fx is about 40 dollers cheaper and I don't see too many differences between the two if any. The main reason im posting this is because i really cheaped out on my firwt build and i wont make the same mistake to so if the sabertooth is worth the extra 40 i have no problem paying it but i also dont want to waste money. Please help and post some thoughts!
it depends on your needs, both boards are sollid. The Sabertooth has a better vreg 8+2 powerphase and digi vrm. the Asus M5A99Fx pro R2.0 has a 6+2 powerphase and digi vrm.
It all depens on if you wanne go into overclocking, and on which level.The Asus M5A99FX pro R2.0 is a sollid board for basic overclocks. upto 4.6 ghz without any pain, but if you wanne go into extremer level of overclocking, then the sabertooth is the better choice.
I would say go for the 990fx pro and save some money. Otherwise I think the crosshair v formula is a better highend board with more features if you are looking to spend more
I would spend the money on the Crosshair V Formula-- specifically because it has the same VRM solution as the Sabertooth, better audio and Intel LAN. My 2c
