Asus rt-ac66u, is it possible to chose what goes through vpn?
I tend to game a lot but want to have my vpn to be set up for almost all traffic except for games. Anyway to achieve this? Currently im running asuswrt-merlin custom firmware just so i could use a vpn on it.
So my main question is it possible to manage traffic on this firmware cause I cant find the option to do so anywhere and if no whats the firmware youd recommend to do that seeing I chose this one as its the closest to stock experience (mostly in case my less tech savy family needs to get on it once in blue moon)
The short answer is, you can't.
But take a look at this thread.
This is possible if you put DD-WRT on the 66U.
http://www.dd-wrt.com/wiki/index.php/Asus_RT-N66U
Or pFSense.
https://forum.pfsense.org/index.php?topic=91987.0
Basically, the default software can't do it, but custom can.
Didn't we literally get a 3 video tutorial on how to do this?
thank you I'll check it out!
And fair enough I thought so, seeing the firmware is modded itself I thought that there might be some way around it
