I was interested in the NH-D15 but it says on there site it didn't work on it.
http://www.noctua.at/main.php?show=productview&products_id=68&lng=en&set=1
any others you know of or is it that it works and they just don't have it listed on there site?
Is this not the motherboard you're looking for?
I don't have any recommendations for a different X99 mobo off the top of my head, but you could still use the NH-D15 on that board. It'd just, as stated in the imagee above, cover a PCI-E slot.
thank you.
I am even looking at the site an can't find it.
our you sure it the NH-d15 no the new nh-d15s model.
Yeah, I'm sure. It's here.
If you're on chrome, use ctrl+f and just type in "Rampage Extreme", should take you to it.
no I am on internet explore in windows seven.
thank you very much those, so all I have to do is more the graphics card down once.
According to the noctua site, yes. It's up to you whether you want to sacrifice a PCI-E slot though.
I bought the Asus x99-S board, which although fully compatible on that list with the DH-15, means the heatsink actually touches the GPU. I've moved the GPU down a space and it seems fine at the moment.
