I bought a radeon r7 260x oc from asus and it cannot launch any games or even the GPU tweak software that came with it. The driver updates are no help at all either please help.
thanks
thanks
We're going to need a little more than that...
Does it give you an error? Blue screen of death? Can you take a screenshot of what actually happens or does it just launch and crash?
Need more info than that....did you plug in the 6pin pcie power conector?
Everything was pluged in and working but it would say I needed a dierect x compatible card if I wanyed to launch crysis 3 and it said that it did not support a game that used a pixel shader whwn I tried ro launch chivalry
I am just going to return it
wtf dude!?!?!?! what happens if you try to reinstall DirectX? have you tried the card in another machine? have you tried uninstalling the old drivers? have you tried the beta drivers? do you have a psu? and if yes what kind of psu? have you done anything at all apart from reinstalling the drivers probably on top of older drivers?
either give more details in somewhat understandable language or don't ask at all...
it runs but the games will not launch at all even though I have all of the updated beta drivers and all the direct x and Microsoft net programs are up to date. I am running windows 7 if that helps.
I got It working. Had to reinstall windows and start from the beginning.
Good to hear.
Lucky you didn't jump the gun and return it to the retailer as 'faulty' hey?
