Has anyone else had problems with the Asus r7 260x? Mine has been crashing and freezing. It seems to be a driver issue but i have tried everything. The only solution seems to be to disable the drivers. But then the card is so weak it cant even watch youtube in full screen. Does anyone Have a solution or will i have to wait it out
If it can't watch youtube it's the CPU. Youtube has nothing to do with the GPU.
But when the drivers are installed it can and the cpu isn't even hitting 50% of max output. it also happens with almost anything, Vimeo Blip Rutube
if what you're saying is correct it's a bad card, any gpu in the past decade can do videos just fine even on windows default drivers
