Asus Pro WS WRX80e U.2 drive or Hyper card for fast large expansion?
I’ve got two 2tb nvme gen 4 drives, but I would like a chunk of larger working space for large video files (300-600gb ).
4tb nvme drives striped in the Hyper card could yield a larger volume, or go with a U.2 drive of higher capacity ( 8tb + ).
The 4tb gen 4x4 nvme drive are around $700-999
the U.2 7.68 are around 1300+
I guess the U.2 would have somewhat slower speed but have the benefit of a single volume and no raid overhead.
The cost is sort of a wash.
A regular 8tb ssd would be much less expensive or gen3 nvme be about the same cost as the U.2 but somewhat slower.
Pros-cons I’m missing?
I personally went with Kioxia KCD6XLUL7T68 Hard Drive CD6 7.68TB NVMe PCIe 4x4 2.5in U.3 | Wiredzone
Lots of capacity, and power loss portection.
@markwoll
Are you willing to experiment a bit?
My personal preferred setup is using NVMe SSDs in external backplanes to be able to easily swap them.
A part list:
  1. Delock 89030 PCIe x16-to-4x-SFF-8654 bifurcation card: Delock Products 89030 PCI Express x16 Card to 4 x internal SFF-8654 4i NVMe - Bifurcation
  2. Delock 85081 SFF-8654-to-SFF-8643 cable: Delock Products 85081 Cable Slim SAS SFF-8654 4i > Mini SAS HD SFF-8643 50 cm
  3. Icy Dock ToughArmor MB699VP-B 4 x U.2 NVMe SSD backplane: MB699VP-B V2_ToughArmor Series_REMOVABLE U.2 / M.2 SSD ENCLOSURES_ICY DOCK manufacturer Removable enclosure, Screwless hard drive enclosure, SAS SATA Mobile Rack, DVR Surveillance Recording, Video Audio Editing, SATA portable hard drive enclosure
(Note: A V2 revision of this backplane has been announced, maybe PCIe Gen4 SSDs are going to be less of an issue then)
I got the V1 and while Samsung PM1733 Gen4 U.2 SSDs work fine with their full speeds, it throws PCIe errors when under full load depending how well the cables are plugged into their sockets and how well they are shielded.
An example benchmark screenshot on a Ryzen 3000 system with the backplane where I went looking into how to maybe prevent the PCIe errors from happening at all with extra shielding of the connectors and cables.
I have extensively molested poor @wendell with this, don’t know if this topic might get also addressed in a video like the AMD chipset RAID stuff but my DIY solutions with copper tape and glueing the connectors in place with a very thinn layer of epoxy so that the cable connections are always “under pressure” and can never become loose in any way were not something that could be recommended to less lunatic users…
(According to Wendell… :clown_face:)
Here is a lamentable experiment with connecting the backplane to an ordinary M.2-PCIe slot:
The kioxia looks interesting. Also unobtanium . sigh.
