I have both ethernet connected and the IPMI is served on the “wrong” one. (Basically an enormous network has scope on my IPMI).
I don’t seem to be able to edit any setting from the bios: whatever I do will either cause it saying that nothing has been modified or an immediate reboot.
Any clear way to specify on which Ethernet port the IPMI should act?
not sure but it might be possible to reach them on both ports. in which case you have to reserver a DHCP address for that IPMI’s MAC address and go from there.
In server managment, i saw it was possible to specify static IP addresses as well.
