So i got a Asus Pro WS WRX80E-Sage board that hosts a bunch of PCIe 4.0 NVME drives. As i kept adding drives, the dmesg log kept getting fuller and fuller of errors like the ones below.
Kernel 5.12.14-arch1-1
They go through all the drives at random, and don’t appear to be dependent on load, system temperature, whether the drive is in the expansion card or directly on the board or anything else i noticed.
The message says it was corrected by hardware and no action is required, the google says these are safe to ignore, but the problem is that the log is completely full of them to the point of nothing else being visible.
So, is that a sign of some problem, and if not is there a way to turn these off?
I’ve grepped the kernel code for these lines, but i can’t make enough sense of it to find out if there is a way to disable them or feel safe enough to comment them out. They do use a different set of words for uncorrected errors, which are missing in my logs, thankfully.
[94781.661358] {18945}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 514
[94781.661363] {18945}[Hardware Error]: It has been corrected by h/w and requires no further action
[94781.661364] {18945}[Hardware Error]: event severity: corrected
[94781.661366] {18945}[Hardware Error]: Error 0, type: corrected
[94781.661368] {18945}[Hardware Error]: section_type: PCIe error
[94781.661369] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661370] {18945}[Hardware Error]: version: 0.2
[94781.661371] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661373] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661375] {18945}[Hardware Error]: slot: 0
[94781.661376] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661376] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661378] {18945}[Hardware Error]: class_code: 010802
[94781.661379] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661380] {18945}[Hardware Error]: Error 1, type: corrected
[94781.661381] {18945}[Hardware Error]: section_type: PCIe error
[94781.661382] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661383] {18945}[Hardware Error]: version: 0.2
[94781.661384] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661385] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661387] {18945}[Hardware Error]: slot: 0
[94781.661387] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661388] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661389] {18945}[Hardware Error]: class_code: 010802
[94781.661390] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661391] {18945}[Hardware Error]: Error 2, type: corrected
[94781.661392] {18945}[Hardware Error]: section_type: PCIe error
[94781.661393] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661394] {18945}[Hardware Error]: version: 0.2
[94781.661394] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661395] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661397] {18945}[Hardware Error]: slot: 0
[94781.661397] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661398] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661399] {18945}[Hardware Error]: class_code: 010802
[94781.661400] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661401] {18945}[Hardware Error]: Error 3, type: corrected
[94781.661402] {18945}[Hardware Error]: section_type: PCIe error
[94781.661402] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661403] {18945}[Hardware Error]: version: 0.2
[94781.661404] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661405] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661406] {18945}[Hardware Error]: slot: 0
[94781.661407] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661408] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661409] {18945}[Hardware Error]: class_code: 010802
[94781.661409] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661410] {18945}[Hardware Error]: Error 4, type: corrected
[94781.661411] {18945}[Hardware Error]: section_type: PCIe error
[94781.661412] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661413] {18945}[Hardware Error]: version: 0.2
[94781.661414] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661415] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661416] {18945}[Hardware Error]: slot: 0
[94781.661416] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661417] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661418] {18945}[Hardware Error]: class_code: 010802
[94781.661419] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661420] {18945}[Hardware Error]: Error 5, type: corrected
[94781.661421] {18945}[Hardware Error]: section_type: PCIe error
[94781.661422] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661423] {18945}[Hardware Error]: version: 0.2
[94781.661423] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661424] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661425] {18945}[Hardware Error]: slot: 0
[94781.661426] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661427] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661428] {18945}[Hardware Error]: class_code: 010802
[94781.661429] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661430] {18945}[Hardware Error]: Error 6, type: corrected
[94781.661431] {18945}[Hardware Error]: section_type: PCIe error
[94781.661431] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661432] {18945}[Hardware Error]: version: 0.2
[94781.661433] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661434] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661435] {18945}[Hardware Error]: slot: 0
[94781.661436] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661437] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661437] {18945}[Hardware Error]: class_code: 010802
[94781.661438] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661439] {18945}[Hardware Error]: Error 7, type: corrected
[94781.661440] {18945}[Hardware Error]: section_type: PCIe error
[94781.661441] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661442] {18945}[Hardware Error]: version: 0.2
[94781.661443] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661444] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661445] {18945}[Hardware Error]: slot: 0
[94781.661445] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661446] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661447] {18945}[Hardware Error]: class_code: 010802
[94781.661448] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661449] {18945}[Hardware Error]: Error 8, type: corrected
[94781.661450] {18945}[Hardware Error]: section_type: PCIe error
[94781.661450] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661451] {18945}[Hardware Error]: version: 0.2
[94781.661452] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661453] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661454] {18945}[Hardware Error]: slot: 0
[94781.661455] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661456] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661457] {18945}[Hardware Error]: class_code: 010802
[94781.661458] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661459] {18945}[Hardware Error]: Error 9, type: corrected
[94781.661459] {18945}[Hardware Error]: section_type: PCIe error
[94781.661460] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661461] {18945}[Hardware Error]: version: 0.2
[94781.661462] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661463] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661464] {18945}[Hardware Error]: slot: 0
[94781.661465] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661465] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661466] {18945}[Hardware Error]: class_code: 010802
[94781.661467] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661468] {18945}[Hardware Error]: Error 10, type: corrected
[94781.661469] {18945}[Hardware Error]: section_type: PCIe error
[94781.661470] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661471] {18945}[Hardware Error]: version: 0.2
[94781.661472] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661472] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661474] {18945}[Hardware Error]: slot: 0
[94781.661474] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661475] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661476] {18945}[Hardware Error]: class_code: 010802
[94781.661477] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661478] {18945}[Hardware Error]: Error 11, type: corrected
[94781.661479] {18945}[Hardware Error]: section_type: PCIe error
[94781.661480] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661480] {18945}[Hardware Error]: version: 0.2
[94781.661481] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661482] {18945}[Hardware Error]: device_id: 0000:43:00.0
[94781.661483] {18945}[Hardware Error]: slot: 0
[94781.661484] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661485] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661486] {18945}[Hardware Error]: class_code: 010802
[94781.661487] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661487] {18945}[Hardware Error]: Error 12, type: corrected
[94781.661488] {18945}[Hardware Error]: section_type: PCIe error
[94781.661489] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661490] {18945}[Hardware Error]: version: 0.2
[94781.661491] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661492] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661493] {18945}[Hardware Error]: slot: 0
[94781.661493] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661494] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661495] {18945}[Hardware Error]: class_code: 010802
[94781.661496] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661497] {18945}[Hardware Error]: Error 13, type: corrected
[94781.661498] {18945}[Hardware Error]: section_type: PCIe error
[94781.661499] {18945}[Hardware Error]: port_type: 0, PCIe end point
[94781.661499] {18945}[Hardware Error]: version: 0.2
[94781.661500] {18945}[Hardware Error]: command: 0x0406, status: 0x0010
[94781.661501] {18945}[Hardware Error]: device_id: 0000:44:00.0
[94781.661502] {18945}[Hardware Error]: slot: 0
[94781.661503] {18945}[Hardware Error]: secondary_bus: 0x00
[94781.661504] {18945}[Hardware Error]: vendor_id: 0x144d, device_id: 0xa80a
[94781.661505] {18945}[Hardware Error]: class_code: 010802
[94781.661506] {18945}[Hardware Error]: bridge: secondary_status: 0x0000, control: 0x0000
[94781.661534] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661536] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661539] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661545] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661546] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661548] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661553] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661554] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661556] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661561] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661562] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661563] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661568] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661570] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661571] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661576] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661577] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661579] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661584] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661585] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661586] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661591] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661592] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661594] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661599] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661600] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661601] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661606] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661608] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661609] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661614] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661615] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661617] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661621] nvme 0000:43:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661623] nvme 0000:43:00.0: [ 0] RxErr (First)
[94781.661624] nvme 0000:43:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661629] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661630] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661632] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
[94781.661637] nvme 0000:44:00.0: AER: aer_status: 0x00000001, aer_mask: 0x00000000
[94781.661638] nvme 0000:44:00.0: [ 0] RxErr (First)
[94781.661639] nvme 0000:44:00.0: AER: aer_layer=Physical Layer, aer_agent=Receiver ID
