ASUS P8Z77-V PRO drivers
So before installing windows on to my newly built pc, I was just roaming around the Asus support website looking for drivers for this particular motherboard. Andd..... I came across this: http://support.asus.com/download.aspx?SLanguage=en&m=P8Z77-V%20PRO&os=8
This just created a whole lot of confusion for me. I saw Newegg's video on getting the drivers and the video explained downloading the LAN, USB, and Chipset drivers. I see the LAN but nothing else.... what exactly is the qualified vendor list drivers??? What also bothers me is that the drivers say "Beta Version"!!!????
oh, and since I'm saving up to buy a decent graphics card, this build won't have a gpu for a month or so.. that means I'm gonna use the motherboard's video ports. Do those require separate drivers too??
I might just install the drivers of the motherboard CD, if that's the best way to go
All the other drivers are most propably propriotry and built into most OS Kernels. So the only one you shall need is the LAN driver. Though pop the CD in just incase to see if there are any on there.
