Asus Nvidia gtx 780 ti Manjaro boot problem
Hi!
When I install my Asus 780 ti i cant boot. I get to GRUB, tryed all start options but it will not start. I also tryed running from usb but that is the same problem.I get the Manjaro boot logo and after 3 green dots it frezes.
I have installed the linux310-nvidia drivers but that don´t help.
Someone had the same problem?
Thanx
What was your previous gpu?
right now I have to run on the GPU on my CPU, 7690K...
Its now solved, if someone have the same problem. Here is the solution
force latest Nvidia driver install:
sudo mhwd -f -i pci video-nvidia
remove intel drivers:
sudo mhwd -r pci video-intel
By next restart install the GPU and you are good to go.
