Hello everyone, So i have a Asus N66U and i recently got 200 Mbps internet speed upgrade but my router doesn’t give me speeds faster then 120 Mbps but when i change my wired connection directly to the modem i get over 200 Mbps any one know whats wrong?
The asus router is a gigabit router i believe, and is limited to 1000Mbps which is 125MB/s. I suggest getting another 1 Gb ethernet cable into the router and do link aggregation somehow etc.
Please confirm you're hard-wired into the Ethernet on your router as well. If you're running into issues still I would suggest you go ahead and reset that router, and if you're still having issues see if there's a setting that handles the speeds.
