Asus m5a97 r2.0 cpu cooler
hi guys
i'm looking for a cpu cooler for my amd 6300.
my mobo is asus m5a97 r2.0 and my ram is G-Skill 8GB Ripjaws X.
i want to be able to use all 4 ram slors without #1 being blocked, pretty quiet and good for moderate OC'ing.
all ideas welcome.
I use a corsair h100i water cooling for my fx8350 I haven't been ablemtomget my CPU over 30oC
I have an M5A97 Evo R2.0 and the 4350 and I just ordered the Xigmatek Dark Knight II, it's a tower cooler that should leave you enough room for the ram I believe, here's a benchmark page I found from September:
 http://www.techspot.com/review/707-best-cpu-coolers/page6.html
Hi I have that same mobo, I use the Coolermaster EVO 212, it works fine and doesn't block any ram, and its fairly cheap
^Right there with you. I've got the EVO flavour mobo. No DIMM slots being blocked
Here is a Hyper 212+ before the fan was installed, with same CPU and MOBO, its Kingston Hyper ram. With the fan on the front it may touch some taller ram in the first slot. You could mount the fan on the back for a pull set up but if you are only using 8gig of ram, 2x4 DIMMs, not to worry, you use slots 2 and 4 as recommended in the manual. You could also just slide the fan up a BIT on the heatsink.
Oh and OC at 4.2 no problem can go 4.4 ,but not much improvement in games, so I backed off a bit
Just installed the Dark Knight II, it's idling at about 26C for my 4350 and doesn't interfere with RAM slots, with the fan installed on the side facing the RAM, It is quite tall though, it has about 2mm headroom between the top of teh heatsink and my side panel
