oday I am going to be buying a Motherboard, Hard Drive, and Case for my first build. I know that the case (Fractal Design Define R4) and the WD caviar blue 1tb HDD will work with everything I have. I already bought an FX-8320 CPU, and I have been reading that it does not work with Asus' M5A97, 970 chipsets. Her's my build if you want to see it. Please Help because I will be buying this today!!!! http://pcpartpicker.com/p/2vz6h
Please help because I have to buy these parts today
Deleted duplicate thread; site messed up, or you double clicked.
Either way, the 8350 and 8320 should work just fine with the latest BIOS.
What do you mean by "Deleted duplicate thread; site messed up, or you double clicked." and also the the new BIOS for this motherboard is Bios 2106, the Cpu i have was integrated at BIos 1006, and I have no Idea what the default Bios is for the Mobo. Some people says its working fine, but I always have doubts!
yes it wil work. its not the best combination, but it will work without issues. dont overclock to much
