Asus GTX 760 120 volts AC through HDMI Cable
Hello everyone!
I'm a new member to this site, but have been following Tek Syncicate on YouTube for quite a while now. I am also not new to hardware or the like, but this is probably one of the weirdest problems I have ever come across. If there's a better place to have posted this I'm sorry, but I thought since it's heavily related to the GPU that it would be a good place to try.
Backstory:
I have a Crown XLS1000 plugged into a Pioneer 5.1 receiver powering some subs for my home theater. I have an HDMI cable running to the receiver from my PC because it's pretty close and in the same room. Today I took the amp and used it to power something else, and when I put it back and went to plug back in the RCA's, I touched one just randomly and received a pretty substantial shock from it. I eventually realized that I was only being shocked when I was grounding myself (touching the chassis of the Crown amp). I didn't really think much of it or understand what was happening, so I just plugged in the RCA's, fired up everything and there we're no problems so I just left it. After around an hour or so I left my house, and when I came back and tried to turn everything on, the receiver wasn't being recognized on my computer. So I unplugged everything (receiver, HDMI cable on computer and receiver) and restarted my computer. It solved nothing. When I would plug in the HDMI or turn on the receiver the computer would give that ding that it recognized a new device being connected, but under audio devices it would show up as not being connected. So I took a multimeter to the RCA's running from the sub out on the receiver and grounded the other probe to the wall outlet and I was getting a full 120VAC (volts AC) coming from it. So I tried troubleshooting a couple other things and eventually found out the voltage was coming from the HDMI cable. It runs kind of close next to some power cables so I pulled the cable away from the power cables and tested it again and it was still showing 120VAC. So then I thought well the only way it would be getting power now was from the graphics card or something, so I unplugged the cable from my card and no voltage was coming through.
TL;DR - Somehow I'm getting 120 volts AC over an HDMI cable plugged into my Asus GTX 760 and I have no idea why. What would be causing this?
System specs:
ASRock Z77 Extreme4 i5-3570k @ 4.2Ghz
8GB Crucial Ballistix Sport
Asus GTX 760
2 - 1TB Seagate Barracuda
1 - 1TB WD Green
Corsair HX750 80Plus Gold
CM Storm Trooper Full Tower
I think there's a way to send power to other devices using an hdmi cable, similar to PoE(power over Ethernet). I think you can send an internet connection over hdmi as well.
Never used anything like that myself, sorry if i didn't seem like much help.
Maybe you were probing the hot conductor on wall outlet instead of the ground, or perhaps there is a short somewhere between hot and ground. I can't imagine any other explanation. Really a short like that should trip the circuit breaker unless it is a very high impedance. You might test for shorts between the computer chassis and the power input pins. Only the middle pin should be grounded. You could also test the power cables for shorts between pins. On the outlet, ground and neutral should have continuity to each other, but neither should have continuity to hot. To be safe, you can test the outlet's wiring after flipping off the circuit breaker first. There are also outlet testers you can get somewhere like Home Depot that just plug in and have indicators that show any wiring errors.
Out of curiosity, what sub do you use with that amp? (Wild guess, something by JBL?)
Nah, I was touching the positive probe on the multimeter to the outside thing (can't for the life of me think of the word right now) of the HDMI plug itself and then the negative probe to the screw inbetween the two actual outlets because those outlets aren't actually grounded, and it gave me a legit 120V. I have no idea what is causing it. The weird thing too is that my computer is running perfectly fine, and if I plug the HDMI cable into my TV instead of the receiver the PC recognizes the TV no problem. The 120V is just screwing with the receiver. Also, everything on the inside of a comp runs on DC power, so how the hell is 120V AC passing through the card and going through the HDMI cable without damaging anything?
Pertaining to the subs, I have the Crown powering two Sundown SA-12's wired up to 8 ohms in a 2.8ft^3 box tuned to 37hz. It's basically a car sub stage but I traded an old build for the pair and the box. It sounds absolutely incredible, and I can't complain about a single thing about them.
It's alright, but I don't think that kind of power is 120V AC, it's probably like 5V DC.
UPDATE:
Every single device inside my case is charged with the voltage. Both of my graphics cards (760 and 460, use the 460 for mining) all of my hard drives, the freaking heat sinks on the graphics cards and the back panels of every expansion card in my system. Basically, everything has 120V running through it except for the case, which is why I guess nothing has exploded yet, because the voltage has nowhere to go, so the internal voltage is just up there and not actually doing anything. Most likely my power supply has some sort of short inside causing it to send all this voltage into everything, which will be so much fun to deal with.
Thanks for everyone's help anyways. Now starts an RMA adventure!
