Hi,
I purchased ASUS FX505DT recently and installed Manjaro Linux with GNOME. I have an issue where screen starts flickering after I press Super+L combo.
Note: This is an AMD+NVIDIA GTX 1650 combo laptop and I have not installed NVIDIA drivers. noveau has been blacklisted and it is solely running from Vega 8.
Here are my logs (I can’t attach files as I’m new user):
hwinfo:
15: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.0fv+L4rZjl9
Parent ID: mnDB.CB0G3oMQsS4
SysFS ID: /devices/pci0000:00/0000:00:01.1/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "nVidia TU117M [GeForce GTX 1650 Mobile / Max-Q]"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x1f91 "TU117M [GeForce GTX 1650 Mobile / Max-Q]"
SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
SubDevice: pci 0x109f
Revision: 0xa1
Memory Range: 0xf6000000-0xf6ffffff (rw,non-prefetchable,disabled)
Memory Range: 0xc0000000-0xcfffffff (ro,non-prefetchable,disabled)
Memory Range: 0xd0000000-0xd1ffffff (ro,non-prefetchable,disabled)
I/O Ports: 0xf000-0xf07f (rw,disabled)
Memory Range: 0xf7000000-0xf707ffff (ro,non-prefetchable,disabled)
IRQ: 255 (no events)
Module Alias: "pci:v000010DEd00001F91sv00001043sd0000109Fbc03sc00i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #27 (PCI bridge)
28: PCI 500.0: 0300 VGA compatible controller (VGA)
Unique ID: Ddhb.CeZIxHbHTfA
Parent ID: JZZT.A_VqgZKlSp2
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:05:00.0
SysFS BusID: 0000:05:00.0
Model: "ATI Picasso"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x15d8 "Picasso"
SubDevice: pci 0x18f1
Revision: 0xc2
Driver: "amdgpu"
Driver Modules: "amdgpu"
Memory Range: 0xe0000000-0xefffffff (ro,non-prefetchable)
Memory Range: 0xf0000000-0xf01fffff (ro,non-prefetchable)
I/O Ports: 0xc000-0xc0ff (rw)
Memory Range: 0xf7500000-0xf757ffff (rw,non-prefetchable)
IRQ: 24 (no events)
Module Alias: "pci:v00001002d000015D8sv00001043sd000018F1bc03sc00i00"
Driver Info #0:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
Attached to: #21 (PCI bridge)
34: None 00.0: 10002 LCD Monitor
[Created at monitor.125]
Unique ID: rdCR.j14EuMcxKHD
Parent ID: Ddhb.CeZIxHbHTfA
Hardware Class: monitor
Model: "LM156LF-GL03 LCD Monitor"
Vendor: NCP "LM156LF-GL03"
Device: eisa 0x0036
Resolution: 1920x1080@60Hz
Year of Manufacture: 2018
Week of Manufacture: 1
Detailed Timings #0:
Horizontal: 1920 1968 2000 2180 (+48 +80 +260) -hsync
Vertical: 1080 1083 1088 3205 (+3 +8 +2125) +vsync
Frequencies: 335.47 MHz, 153.89 kHz, 48.01 Hz
Detailed Timings #1:
Vertical: 1080 1083 1088 1282 (+3 +8 +202) +vsync
Frequencies: 335.47 MHz, 153.89 kHz, 120.04 Hz
Driver Info #0:
Max. Resolution: 1920x1080
Vert. Sync Range: 48-120 Hz
Hor. Sync Range: 154-154 kHz
Bandwidth: 335 MHz
Attached to: #28 (VGA compatible controller)
inxi
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=0ce2cc54-b760-4b30-af00-425ac1af7399 rw audit=0 quiet
apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter> UEFI: American Megatrends v: FX505DT.310 date: 12/24/2019
Battery: ID-1: BAT0 charge: 12.8 Wh condition: 43.6/48.2 Wh (90%) volts: 10.8/11.9 model: FX50442 type: Li-ion serial: N/A
status: Discharging
CPU: Topology: Triple Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 L2 cache: 1536 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 25164
Speed: 1345 MHz min/max: 1400/2100 MHz boost: disabled Core speeds (MHz): 1: 1345 2: 1250 3: 1447 4: 1831 5: 1843
6: 1384 7: 1211 8: 1210
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: N/A alternate: nouveau
bus ID: 01:00.0 chip ID: 10de:1f91
Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:15d8
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-1:2 chip ID: 13d3:56a2
serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RAVEN (DRM 3.37.0 5.7.15-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0 state: down mac: <filter>
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: rtw_pci v: N/A
modules: rtwpci port: d000 bus ID: 04:00.0 chip ID: 10ec:c822
IF: wlp4s0 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 13.41 GiB (2.8%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C scheme: GPT
Partition: ID-1: / raw size: 97.16 GiB size: 95.13 GiB (97.91%) used: 13.41 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p6
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 52.9 C mobo: N/A gpu: amdgpu temp: 52 C
Fan Speeds (RPM): cpu: 2700
Info: Processes: 308 Uptime: 5m Memory: 21.52 GiB used: 1.76 GiB (8.2%) Init: systemd v: 245 Compilers: gcc: 10.1.0
Packages: pacman: 1262 lib: 337 flatpak: 0 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.05
xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
EDID:
00ffffffffffff003870360000000000
011c0104a5221378036850985c588e28
1b505400000001010101010101010101
0101010101010b8380047138ca403020
350058c21000001a0b83800471384d48
3020350058c21000001a000000fd0030
789a9a22010a202020202020000000fe
004c4d3135364c462d474c30330a00c9
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 1
range: (0, 1)
abm level: 0
range: (0, 4)
max bpc: 16
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 64
supported: 64
non-desktop: 0
range: (0, 1)
1920x1080 120.04*+ 48.01
1680x1050 120.04
1280x1024 120.04
1440x900 120.04
1280x800 120.04
1280x720 120.04
1024x768 120.04
800x600 120.04
640x480 120.04
Please help.
