ASUS 760 - Lian Li PC TU100
I've bombed PM's to all kinds of people regarding this question including Logan, no answers yet.
So I'll try here
Logan stated that this card (ASUS GTX760 DirectCU II, not the 760 mini) can fit in the Lian Li PC TU100 case.
The official Lian Li report says that it can only hold graphics cards up to 19cm, but I can imagine that what they mean is; the gap on the side is 19cm. I'm not sure about it.
I can imagine it being inserted in the case a bit tilted, and then plugged into the mobo.
The case on itself is about 25cm in depth
The card is 21cm in length.
Can anyone verify this? This is quite "urgent"
well i can verify what you said been to 3 different resellers and they all say 190mm :/
I'm having this crazy idea of buying the 760 DirectCU II, and sawing a piece of the plastic and heatsink (which are both stretching out of the PCB itself about ), but still having two fans and the copper pipes
I measured it (on the screen) and found out that it would be about 190~193 mm
Crazy idea, I know
Or you can get another card or case ;S
760 mini or 670 mini
Although, they're bit weaker on the cooling side, only have one fan and smaller heatsink in general
Yes the Asus GTX 760 Direct CUii will fit in the TU-100B. I just did it in a build a couple of days ago. Its easier to install if you take the front intake fan out and then install the card into the MOBO, but YES it can be done and it works just fine.
http://pcpartpicker.com/b/Bqpbt6
