ASUS 760 and 250D
So I've been looking all over the internet for this info and just can't find it. I was wondering will a ASUS GTX760 DirectCUII fit in the Corsair 250D. I understand a 780/Ti won't but nothing about the 760.
I know my cards' dimensions are 21.84 x 12.7 x 3.81 Centimeters (8.6x5x1.5 in) Thank you for your help in advance!
Yeah it should fit easily, apparently the case supports up to 290mm GPUs. Your card is only 220mm in length.
http://www.pc-specs.com/case/Corsair/Corsair_Obisidian_250D/1011
