I run a nonprofit RPG library. We travel around sharing the library at events and teach people to use games to work with at risk teens and Vets with PTSD. I am currently deployed to Iraq and have some volunteers running the library for me, awesome people. In the military I am a broadcaster and have not had to build an editing work station for ages , due to having a good editing work station at the Army’s dime.
Well we are going to be doing video tutorials and more for the library when I get home and looking for help of what is the best road to go down for an editor working in a 4k footage.
I have good monitors and multiple 10g network NAS drives and a couple thunderbolt 3 drives.
Thanks in advance for advice.
David
Chief Librarian
Alexandria RPG
Here is a good guide for that software
Mind you it has dual Titan RTX GPUs
I would probably Aim for a R7 2700 CPU (cheaper and not tons of performance loss)
Ram would probably target 32gb in a 2x16 setup (so you can expand more later if needed)
Storage maybe 512gb nvme for OS and Scratch pref samsung pro due to wear/tear and not having a cache like evo drive
I don’t see anything beating this price performance combo.
$1530.
Ryzen 7 3700X + Nvidia RTX 2070 Super + MSI B450 Tomahawk Max.
32GB DDR4-3200 CL16 RAM, 1TB Samsung 970 Evo SSD+ 6TB HDD.
600W 80+ Rosewill PSU. https://pcpartpicker.com/list/qWRVcq
If that is little costly, go for a Ryzen 7 2700 + RTX 2060 Super. Not sure anything cheaper can handle 4K video editing.
Heck I bet someone on here could donate your cause a system. Any takers??
The only AMD that should matter in this graph should be the 5700XT, which lags decently behind the RTX2060. The former crushes the 2060 in games…which means either AMD’s new offering sucks at “compute” or the software is nowhere near as optimised as it should be.
Vega 64 is way too old and inefficient, and Radeon 7’s drivers are laughable according to the internet.
So yeah, for stability, efficiency and reliability, I’d still go to Nvidia.
I will be back in the US in Aprilish time frame and looking to build then. Maybe there will be a better logical option for video performance by then. Thanks again to everyone that is willing to help out. It is crazy how hard these choices get when it isn’t your money and funds are tight.
I think I have something along the lines of what I will be ordering. It is more than I want to spend, as what the Nonprofit can’t cover I will pay for out of pocket.
The MOBO was chosen as it has thunderbolt 3 support and some future growth as well.
Scythe Fuma performs within a couple degrees of the highest end air coolers, but is significantly cheaper.
The new G.Skill RAM will match the performance the Corsair, but is cheaper.
The 860 Evo you had is a SATA drive, as such it’s limited to SATA speeds. The Crucial MX500 is a great budget SATA drive with good performance.
EVGA power supplies are generally considered very good power supplies for the money. The one I picked for all intents and purposes will perform the exact same as the more expensive Corsair unit.
@AlexandriaRPG let me know if you need any help building the workstation! Also are you a recognized 501( c)(3)? Curious if I can make a donation through my company to get it matched.
Thanks, it has been ages since i have built a computer. I remember ISA slots, IRQ conflicts, having to check ram voltage and the like. I thought I was keeping up with tech but Damn there are tons of little things like everything in the M.2 variety.
