Hi there, could anybody who has this motherboard tell me, which 2 dimm slots are used if using 2 sticks of ram? I ask because I plan on getting a large cpu cooler and would need to know if 2 sticks of Corsair Dominator Platinum will fit!. Thanks.
Those crosair dominator have large heat spreaders, that makes if you gonne buy a realy large cpu air cooler you have a problem with them installing in slot 1/3 dual channel.
ofc you can choose to install them in slot 2/4 thats also dual channel, that realy doesnt matter.
but to be safe, just look for rams with low heat spreader (low profile ram)
like kingston hyper X crosair low profile, or gskil sniper.
grtz Angel
