ASRock Z77 Extreme 4 USB 3.0 Front Panel Issue
I decided to throw this in the motherboard forum since I'm assuming the issue is related to my mobo.
The front panel USB 3.0 ports (I'm using the CM 690 II Advanced case) are running at the same speed as USB 2.0 (roughly 20Mb/s) I've gone through the BIOS and has enabled all my USB 3.0 settings (Legacy and such).
After doing some brief research it seems the Extreme 4 doesn't do USB 3.0. It looks like a very common issue, if anything it seems to be the norm with the board.
If anyone knows anyway I could potentially fix this, or if it's something to do with all Extreme 4s. It would be some nice input.
Edit: I've tried a few USB 3.0 drives in the motherboard's ports and still have 2.0 speeds.
Have you updated the BIOS? If its a known issue BIOS updates are rolled out to remedy things like this.
Grabbed the latest asmedia drivers etc?
