Will i be able to use this memory with z77 extreme 4 mobo, i ask because i can't find the momory on asrock's site with compatibility.
link to ram site ---->http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=&LinkBack=&ktcpartno=KHX18C9T2K2/16X
(ram code: KHX18C9T2K2/16X)
also what do you think about my build is it good
Asrock z77 extreme 4
intel i5 3570k
coolermaster gx750w
if compatable kingston 16gb (2x8192mb) ddr3 1866Mhz
Termaltake Chaser mk1
intel ssd 330series 120gb sata 3 2.5"
500gb hdd 7200 rpm (alreaddy have that)
nvidia gtx 560ti hawk (alreaddy own it)
So why do you need 16 GB of 1866 MHz RAM?
because i am planing to livestream, edit, record, play games... basicly i want to do evrything with my pc
I was about the get an Extreme4 and 16Gb RAM (G.Skill RipJaws X), but then I read somewhere that there were some issues with such a large amount of RAM on the motherboard, so I got scared and bought a Gigabyte GA-Z77X-D3H instead. This has probably been fixed with a BIOS update, but I'd look around and read up about it before making the purchase.
As for compatibility issues, it should work just fine. The reason it wouldn't be on the compatible list would be because the manufacturers can't be bothered testing the RAM with the motherboards.
