I’ve struggled with trying to get this thing to even post since I got this board.
I can access the machine via ipmi but I cannot get the machine to show any video signal
Here are the parts I’m using
ryzen 5 3600
Crucial DDR4-2133 16 GB CL15 RAM
corasir TX550M
Dr.debug doesnt even light up as well
I’ve tried
clearing cmos
reseat RAM
reseat RAM in different locations
reseat CPU
reflash bios via ipmi
For reference: Did you also try removing the BIOS battery for half an hour or so?
Have two of these boards, in the early days sometimes this was the only way to get it to POST, resetting the BIOS via the IPMI had no effect.
On the other hand one of my units also became defective on a hardware level (self-corrupted the content on the IPMI flash chip, tried multiple chips, all were “eaten” after a few weeks and the IPMI became unavailable) so I don’t want to suggest that yours wasn’t.
Be so kind and give a short response if your replacement unit works as expected. Don’t forget to immediately upgrade to the latest (Beta) BIOS and BMC firmware so you don’t go through our lenghty sufferings at this point in time.
No you shouldn’t need to. The bad java applets that are sometimes in the mix have annoyed me to the point where I just hooked up an old VGA cable or something anyway, but it should work without it.
Alright, after asking ASRock Rack support, they said I had the wrong type of RAM. Turns out they were right, I though my ram was UDIMM but it was actually RDIMM…
Anyway bought the ram and tried it, everything boots now…
You’d think if it was a memory problem there would be some kind of error indicator instead of just acting dead, but glad you got it sorted out regardless.
