I’m currently building a server based on the 5975wx.
I seem to have hit a bug with the ASRock wrx80 creator bios.
I can add up to 14 nvme drives with 4 Asus hyper m.2 cards but as soon as I try to add a 15th one I don’t get past boot. Not even into the BIOS.
It hangs with the A0 or A2 error code.
This happens if I add it to one of the PCIE cards but also with the onboard slots or with the u.2.
These are 980 pros.
I am using the x16 slots and they are in x4x4x4x4.
All 14 nvme works but I can’t get past that. Theoretically I have a total of 5 slots left (2 in a card, 2 on board and 1 u.2)
I don’t need more (I moved the OS to SATA SSD) but I am curious.
I have written to ASRock support but could I be missing something I don’t know or is not documented for this motherboard?
^ This. WRX80 creator only has one 6 pin of additional power for pci-e. I was also facing issues with using crapload of copper NICs. Motherboard didn’t post at all. I believe it’s easy to overload it if you use too many devices without external power connectors.
It looks like supply chain issues will force me to use the Asus motherboard but I might encounter the same problem so I’m curious.
PCIe slot power puzzles me. In theory, each slot should be able to provide 75 W, so with 7 slots a motherboard would have to be able to provide 525 W just to the slots. In that context, even the three PCIe power connectors on the Asus are theoretically insufficient (they would only total 450 W)
Yet Asrock Rack advertises a WRX80 motherboard with zero PCIe power connector. What’s the intended use-case for such a board ?
Most bifurcation cards use external power, and graphics cards tend to rely mostly on external power if it’s not a low end consumer card, enterprise cards will include external power for cards that might not even need it for extra compatibility
After 480s started melting mobos everyone kinda steered away from relying on mobo power
at least 16nvme drives + 100G nic + 2 U.2 drive has been tested working simultaneous on asus wrx80. None of them take external power. But note that the asus MB itself took 1 8Pin + 2 6pin to supply pcie slots power. So it is less likely to have asrock issue.
I doubt it’s a power issue imho I think it’s “overuse” or bifurcation on a single board.
Grab one or two of the highpoint cards they have their own plx chips and don’t require bifurcation . Pricey but you could take 2 x 8port cards and it’ll work guaranteed.
I have the 4port ssd7505 for me it works better then e.g the 4port gigabyte card in bifurcation mode .
Not saying bifurcation doesn’t work just perhaps doing it for 4 or 5 slots at the same time.might be where the issue is …
