In a discussion on Reddit I was made aware of an ASRock Rack Industrial W680 motherboard, namely the IMB-X1712. Judging by the connectors (serial ports, PCI slots), it seems like it targets embedded uses, not servers. Still, it has ECC. It also doesn’t IPMI/BMC, ASMedia or otherwise, and instead relies on Intel AMT. @wendell still interesting to you?
Specs shortlist:
Intel® 12th Gen (Alder Lake-S) Core™ Processors with W680 chipset
4 x 288-pin ECC/non-ECC Long-DIMM DDR4 3200 MHz , up to 128GB (32GB per DIMM)
1 x PCIe x16 (Gen4), 1 x PCIe x8, 2 x PCIe x4 (Gen4), 1 x PCIe x4 (Gen3), 2 x PCI
1 x USB 3.2 Gen2x2 Type C, 5 x USB 3.2 Gen2, 2 x USB 3.2 Gen1, 4 x USB 2.0
1 x M.2 Key B, 1 x M.2 Key E, 1 x M.2 Key M, 6 x COM, 8 x SATA3
3 x Intel 2.5 Gigabit LAN
Supports Triple display, 1 x HDMI 2.0b, 1 x DP 1.4a, 1 x VGA
Thinking on it more, just the triple built-in 2.5 GbE make it a great board for a router.
Those serial ports aren’t completely stupid either - some wired home automation stuff uses RS485, and one of them can do that.
PCI slots are probably for specialist stuff, but you can still buy new cards with CAN for them. And CAN is sometimes used in automation as a better alternative to RS485
I need CAN under Linux, not on a freaking Arduino. Supported by SocketCAN at that. And something that’s more reliable than a Pi. So, it’s a CAN card in a server, or a separate ARM box. CAN card is still cheaper.
We’re getting sidetracked, but for a low volume project getting the code working, finding enclosures, etc, etc, employee time isn’t free, you know? From the perspective of a company (which is how I’m looking at it), it’s cheaper to just buy the 200 euro board which is known to work.
Talking shit with people, googling random stuff, found a different board: IMB-X1314, seems like the smaller, mATX, brother. Specs shortlist is the same, it only seems to miss the PCI slots.
-Intel® 12th Gen Alder Lake-S Core™ Processors with W680 chipset
4 x 288-pin ECC/non-ECC Long-DIMM DDR4 3200 MHz, up to 128GB (32GB per DIMM)
1 x PCIex16 (Gen4), 1 x PCIex8 (Gen4), 2 x PCIex4 (Gen4), 1 x USB 3.2 Gen2x2 Type C, 5 x USB 3.2 Gen2, 2 x USB 3.2 Gen1, 4 x USB 2.0, 1 x M.2 Key E, 2 x M.2 Key M, 1 x M.2 Key B, 6 x COM, 8 x SATA3
Support Quad display, 1 x HDMI2.0b, 1 x DP 1.4a, 1 x VGA, 1 x LVDS
