Update
So the motherboard won't work with my cpu so I got a full refund for the motherboard, kind of annoyed at asrock for putting up a compatibility list that isn't correct. Will have to save up for new cpu and try to get both at the same time once I get some money.
Hello all,
seem to be having some issues with posting my new Asrock 990Fx Extreme 3 mobo,
which I was rather looking forward to after a stressful week.
I have done quite a few builds before for friends and this is the first time i've splurged on myself
and something has gone wrong.
This is an upgrade of an old rig and doing this part by part and all old parts were working fine last night
specs:
Asrock 990Fx Extreme 3, Running Bios: 1.70 - 15A (New)
AMD Athlon II X4 645 (AM3 platform) (Old)
Strontium 4GB DDR3 1333MHZ (1 stick) (Old)
Gigabyte HD7750 1GB DDR5 (Old)
ThermalTake Smart 750W (Old)
1st attempt: had a hdd plugged in, no visual.
2nd: took hdd out, no visual.
3rd: plugged in speaker, no beeps, no visual.
4th: no Ram, 3 Long beeps, no visual.
5th: no gpu, no beeps, no visual. -.-
6th: tried VGA instead of hdmi, no beeps, no visual.
7th: Cleared CMOS, used VGA, no beeps, no visual
8th: removed everything except cpu, put everything back in, no beeps no visual
getting tad fustrated now and would appreciate some help :)
Don't want to take long train to return it. (I live in melbourne)
note: after each failed post, psu was turned off for >10secs before trying again
Thank-you :D
