Asrock 970 pro3 or MSI 970A-G43 for a FX-6300 build?
I'm building a $600  budget pc, and was choosing between these two MBs, which one is more reliable? I won't be overclocking much, maybe I'll try to raise it 0.1-0.3 mhz, but nothing more than that.
Which one would you guys recommend? I'm more for reliability, but pros and cons of both would let me decide more easily.
My brother's build has a FX 6300 paired with a MSI 970A-G43 and for what he does it's plenty good. Also I overclocked his 6300 to 4.5Ghz so that motherboard will do some decent overclocking. I don't know much about the Asrock board  but the MSi board is good for a 6300.
