Artifacting
I am artifacting at 64 degrees in the Witcher 2.  What should I do.
Running Crossfire Radeon HD 6950 1gb
Have you overclocked, which drivers are you running?
i've got crossfire 6950's as well.  I get artifacting and screen tearing ALOT.  My solution is always set the frame rates to the monitor's hz.  I've got 60hz monitor so i set my frames to 60fps and if i can't control it, i tend to run V-Sync.  That usually solves my problems with that.
Another symptom of artifacting is related to VRAM.  My video card after 1 year starting acting up giving me an insane amount of artifacting, found out the Memory took a shit and had to RMA the card.
That's all i came across with that issue, hopefully that helps.
no overclock, running 13.8 beta
ill try turnign on vsync
Thanks, it worked
