Im looking to build my first pc. My budget is around £500 and it needs to be loaded with features and be easily upgradable later on. Im looking for any tips or reccommended builds you guys have.
Here's what I definately need:
- CPU at a good price capable of 4.0GHz or more (probably sticking with amd for a good price)
- Great graphics capabilities integrated or from GPU for latest games and use of programming software like eclipse
- Motherboard compatable and reliable with nice featuress on BIOS etc.
- 8gb min memory
- Good case with good routing and USB 3.0 and audio I/O ports easily accessable (probably looking towarrds an itx or other small case variants)
- Reasonable cooling options
- Large storage capabilities min 1TB (so probably not an ssd for now)
- WiFi (reasonable/reliable connectivity)
- PSU to power all this (probably sround 650w)
As i said in the title, this is my first build so any tips would be great. There can be some leniency, aslong as the price stays down. Additional cooling I might not need yet until I start overclocking later on. anything would be better than what im using now which is a laptop at least 4 years old so you can guess the spec im using.
Thanks guys
