Just to be clear even offline, this game need's to be on a SSD.
This game need's setting up correctly in the config file and have a option making differnce between online and offline setting's -.
PlayerProfile config -
mouseSmoothing=0 not 5
Arma 3 config -
GPU_MaxFramesAhead=1 not 1000.
Also whilst you're their you may aswell do you Field Of View setting in the config.
http://hia3.com/tools/ArmA_3_wide-angle_FOV_calculator_online_by_Hi,A3.htm
This is what I call standerd / high setting's for online play for arma 3.
Server's only allow up to 1600 - 1600 Overall - Object distance, but personally I keep Overall 1600- Object around 1100 due to town's can be a arss for fps and for god take turn off HeadBob in option's - Game.
Sampling 100% no less or more,Texture on high - ultra, Object = Normal - high, Terrain = low, Shadow/Cloud = disable, Partials = low, PIP= standerd - Low - Disabled, Dynamic-lights = ultra, HDR standerd = highest.
Everything else just turn off like AA, AO, V sync - DOF- water stuff and what not.
Use Nivida Inspector to put a frame cap to your monitor refresh rate e.g 60MHz = 59.7
For AMD user's I think their is anthor way to frame cap on Crimson.
Feel free to question anything.
